Am I daft?
Started by BigAlan, June 16, 2013, 02:52:22 PM
Well don't answer that correctly but bear with me.
Once a month I tend to remove the brake pads from the calliper and clean everything there is to clean, even the grove in the pads get cleaned out and also the spring retainer takes five minutes to policy up.
Is this a bit much or do we all do this?
The only probable reason for doing this is that I then know what my brakes are like, oh and I also clean the rotor buttons on the disk and make sure they rotate.
BA ... when I have done the basic course of bike mechanics I shall do exactly that ! ....No way are you daft .. it's those little bits that stop your Gtr when it needs stopping so to actually check and clean them every month and thus ensuring all works well seems pretty sensible to me old fruit. Carry On.  :smiley:
Bryn
Did exactly that with the back caliper last week... cleaned it with brake cleaner, pushed the pistons out.. cleaned around them, and then applied a little caliper grease, then it all went back together  ...
peace of mind  :yes:
PS Alan... how did you clean the rotor button thingy's  ?  I reckon WD 40 but it could all end in tears   :rolleyes:
Quote from: Bryn on June 16, 2013, 04:12:15 PM
peace of mind  :yes:
Easy, get a 10mm Allen key and some brake cleaner, squirt cleaner on rotor, insert 10mm Allen key in hole and simply press down a little and turn, it does work a treat. Repeat as necessary.
Bryn
Quote from: BigAlan on June 16, 2013, 04:50:10 PM
Just done it, and every one was solid.... not any more..... Top Tip Alan   :clap:
Quote from: Bryn on June 16, 2013, 05:22:29 PM
See how good this forum is? Someone else told me.
I've never done any of that.. Would not know where to start...  :mfr_lol:
Quote from: Debs on June 16, 2013, 08:18:01 PM
Debs, it's very easy actually, it might be daunting the first time but actually it is easy peasy.
Couple of Allen keys, brake cleaner, copper slip and a rag and away you go.
I must come down to the Poole bike night and then I can show you, I will check with some mates and perhaps organise a trip down.
Sorry, and maybe I'm being a bit dense, but what's a rotor??
Bryn
Quote from: Ros on June 16, 2013, 09:00:06 PM
Front brake discs.. And its the silver rings that need to be set free..  :cool:
Quote from: Bryn on June 16, 2013, 09:02:39 PM
He knows you know..
#11
Quote from: BigAlan on June 16, 2013, 08:33:34 PM
That would be good..
I have Allen keys, copper slip grease and rag but which make of brake cleaner do you recommend?.. Lots on fleabay..
zedmeister
Debs  - i always use WURTH for all my maintenance requirements, top quality products.
get a grip and deal with it
Just out of interest, if you pull on the lever and the piston pops out, will it go back in easy ?
