Quick rivets
Started by simbad, October 23, 2011, 05:03:30 PM
simbad
Anyone had trouble releasing the quick rivets on the fairing located under the seat fairing panels? These are not the pop in and lift out type but unscrew the middle pin and then remove. Mine don't want to unscrew and so it's difficult to remove the rivet.
So far I haven't had cause to remove these. What is it you are trying to do?
What ??? I don't believe it Mr Wolf ... are you telling us there are rivets on your bike that you HAVN'T undone yet ? Rivets that you havn't tampered with ? Rivets that are concealing something that you havn't yet touched ? My Ghast is flabbered  ;D ;) ;)
simbad
Dropped a bolt down there and this seemed the easiest way to get it out.  :-\
Ubertours
Use a really small precision screwdriver to lift the screw head as you turn it . this will start it off and then remove as usual.
Quote from: simbad on October 24, 2011, 10:17:16 AM
Ah, ha. Now I understand. Is it not something you can retrieve with a magnetised bar. Maplins do these, http://www.maplin.co.uk/search?criteria=Magnetic+Pick-Up
A lot less hassle than dismantling the bodywork.
simbad
Thanks for the suggestions ...
