Fairing removal
Started by knightraider, February 26, 2019, 07:10:03 PM
knightraider
I have taken advice from you all and ordered a denali horn.
My next problem is which part of the fairing do i need to remove and how to remove it to replaced my existing horn with the denali.
I want to be careful and methodical so as not to break anything.
Glen
Robbieben
The standard horn us under the lower fork clamp yoke, pick up the wiring from there and run up inside the right hand side of your fairing and mount the compressor unit under the black plastic infill trim, to remove the trim you'll need to remove the screen to access the front screw. Mount the horn itself in the OE position once you remove the standard one.
