New GTR owner
Started by Tony, January 17, 2016, 12:30:29 PM
Tony
Can anyone tell me on the pre 2010 model the center glove box on the tank, when you press in the button should the lid flip up? is there suposed to be a spring because mine doesn't and is very fiddly.  :no:
Quote from: tony on January 23, 2016, 11:51:21 AM
Yes Tony it should..
Tony
Thanks Deb, A trip to the shop to get that checked out then.
Quote from: Tony on January 23, 2016, 06:56:18 PM
:punk:
Its easy enough to remove this box.  there is a lightweight spring in there somewhere and its easy to foul it .  I bet if you take the whole thing off it will work perfectly on the bench!
On mine I have always had to push the button in and the lean on the back a bit for it to pop open.
Works fine on the bench. I just put up with it as I rarely use the glove box.
Tony
Manage to repair my glove box, it was a broken plastic lug on the frame where the cogg pushes on. Super glue did the trick and now opens perfectly.
Thanks for all the advice  :clap:
