led lights
Started by jenros, July 06, 2011, 10:56:12 PM
jenros
evening all!,
new to your forum,few weeks ago i purchased a gtr,ive just bought some "bike viz" bullet style leds. I have fitted 1 each to the underside of the mirror (the part that does not turn,ie- fixed arm). the other two i have fitted inside edge of the air intake scoop., took all afternoon  on sunday,lol!.
Now does anyone know which wire to splice into at the rear of the headlight loom????,im planning to do two on each side.
The manual i have hasent got any wiring diagrams at all,and what is the best way to get to these? is it the nose cone off job or what?
cheers guys,any help would be much appreciated, thanks, Jenros. :)
Do the lights come with a switch? I powered mine from the accessory wires.
jenros
ahhhhhhhhh! didnt think of that!, i was just going to wire them into the lights.thi s wont affect any plug in gizmos would it? i know they only pull a very small amount of power from them,.
Not very good on 12v electrics,give me house hold any time! ha ha,.
thanks, i will have a look on the weekend as im away working until then. ;)
jenros
norman, no theres no switch,why what you got in mind?. i didnt realy want them switched,so when the lights are on,they are on. coz knowing me id forget to turn um on.
Mine have a switch hence why I asked.
If you just want them to come on with the ignition then wire them to the accessory lead. Whats the rating of the lights? That may affect where you draw the power from. If low, then accessory leads are fine.
However, if you intend to run a lot of accessories on your bike I recommend and fuzebox
Ubertours
Because they are LED there is very little power consumtion. Take off the small cover under the nose cone (four press studs) there you will find two wires going to the side light bulbs, just splice into those. Remember to connect the right way around as leds will only work with the correct polarity
jenros
ubertours, thanks very much! that sounds the easiest way for me to do it,i had a play around there when i was fitting the lights,
cheers guys,n thanks for your help,i will try an put a photo up when im done,if i find out how to do it,lol!  ;D
jenros
light fitted n they look stunning fair play. thanks ubertours for your help,that was definatly the easiest and quickest way.
think im gonna get two small side light bulbs to fit inthe nose cone now,well impressed with them. ;D
Mungoo
Thank you. I had not come across that site and it helped a lot. You were right that I really needed to see how Led Light Accessories Connector / Power Wire LED Power Supplies diodes worked and when I saw that understanding the LED was easy.
