Tank bolt torque
Started by Kwikasfuki, June 28, 2014, 03:15:32 PM
Anyone know how tight the tank bolts should be? Can't see it in the manual.
The fuel pump bolts are given as 9.8(nm) 1.0(kgf.m) 87 in·lb  - should I aim for roughly the same?
Just finished replacing the fuel pump strainer. Expect a guide later today. Took so many pics the camera battery has died so waiting on that to charge up.
Zebedee
Never bothered with torquing tank bolts as you should be able to tell if they come loose before it falls off, about 10nm should be fine :)
Zeb
Zebedee
not a cricital enough component to need an accurate torque in my opinion, The only torque settings ive ever really used are inside engines , head bolts, nuts around bearings( wheels and headstock) and the such like.  For me I use torque settings to stop me Over tightening
If you break it off, it's too much..then don't do the others the same way..
Unless a different torque figure is specified, the general values are these in the workshop manual
Thread                                 Torque
diameter
mm                        N·m              kgf·m                        ft·lb
5                      3.4 ∼ 4.9      0.35 ∼ 0.50            30 ∼ 43 in·lb
6                      5.9 ∼ 7.8      0.60 ∼ 0.80            52 ∼ 69 in·lb
8                      14 ∼ 19        1.4 ∼ 1.9                10.0 ∼13.5
10                    25 ∼ 34        2.6 ∼ 3.5                19.0 ∼25
12                    44 ∼ 61        4.5 ∼ 6.2                33 ∼ 45
14                    73 ∼ 98        7.4 ∼ 10.0              54 ∼72
16                    115 ∼ 155    11.5 ∼ 16.0            83 ∼ 115
18                    165 ∼ 225    17.0 ∼ 23.0           125 ∼ 165
20                    225 ∼ 325    23 ∼ 33                 165 ∼ 240
Quote from: doebag on June 28, 2014, 06:07:14 PM
Thread                                 Torque
diameter
mm                        N·m              kgf·m                        ft·lb
Thanks for that. I'll put it in the useful info thread when I get on my main pc
