Removing/Lifting the Fuel Tank
Started by Stephen.Stallebrass, November 17, 2013, 11:59:10 AM
Stephen.Stallebrass
To remove the fuel tank the manual says I must first
Remove Front Fuel Tank Cover
Remove the inner cover
Remove the left and right middle fairings
I don't need to remove it completely I just prop it up in order to route some wires and place my alarm's 'brain & horn' underneath the tank inside of the rear fender as Fred Harmon has done in his Alarm Installation Guide. Like this:
I know there is a grommet on the fairing which goes into a tabbed hole on the tank like this:
My question is:
Can I disengage the grommet and lift the tank without removing all the fairing ?
Following Fred Harmon's Tank Removal Guide he seems to have removed the tank without removing the fairing... just wanted to check if this can be done before I start.
:beerchug:
Stephen.Stallebrass
Ahhh... I thinks this confirms it:
ZG's Install Guide
