Beowulf Rad Guard
Started by Simmo, June 11, 2013, 10:26:53 AM
Simmo
Has anybody fitted the Beowulf Rad guard.  Had a look at one on their web site £53 earth pounds. it appears too only hook over the top lip of the rad and fasten with one bolt at the bottom.
Just wondered if anyone has one fitted and how secure it is.  Any advice ????.
stoketim
fitted mine in 2008 and has not moved  :yes:
Here for a good time, not along time
Quote from: Simmo on June 11, 2013, 10:26:53 AM
It appears too only hook over the top lip of the rad and fasten with one bolt at the bottom.
The old design only used the existing bolt at the bottom while the new design has also a clamp with 2 bolts at the bottom on the left (looking from the front of the bike).
I had mine for about a year now and it is rock solid.
zedmeister
I have an R&G one, it was on the bike when i bought it.
get a grip and deal with it
I've had the Beowulf rad guards on many of my bikes. They do not budge.
Barry7
My one rubbed a hole in the front of the rad after about 17k miles.
Never eat Yellow Snow!
Quote from: Lonewolf on June 12, 2013, 12:35:38 AM
:agree:
- not well made.
- not pre-bent to the curvature of the radiator.
- two hooks at the top are a joke.
- uses flimsy foam tape to keep the guard from rubbing against the radiator. Foam rapidly disintegrates and allows aluminium to aluminium contact.
- my mechanic devised a set of four rubber bungs to (a) keep the guard a healthy distance away from the radiator , and (b) prevent rubbing.
- will not buy another one from them.
Gonome
Better to be old and grey than the alternative!
Barry7
All of those who have not had a problem, may I advise you remove once in awhile and make sure it isn't gently chewing a hole in the front of your rad.
I would have recommend until I had to repair my one.................
keith
have had  boewulf rad guards on my previuos zzr's and gtr ,also have fitted one on my present zzr.i have never had a problem with them.
