headlight bulb
Started by knightraider, February 12, 2013, 11:06:36 PM
knightraider
What headlight bulb do i need for the gtr and is it easy to change. How do you change the bulb.
Glen
H4 globe and yes, very easy to change.
garfield1974
Quote from: Deon on February 13, 2013, 04:57:04 AM
Only if you have smaller hands   :whistling:
To feel wind in hair, you don't need fast bike, you need hair :)
knightraider
How do you change the eadlight bulb?
Glen
Bryn
'Eadlight bulb'. You're not French are you?  :laugh:
Look at the bit where the power  connector is fitted. Behind the light between the forks and back of lights.  Pull off the power connector first.
You then need to remove the rubber boot covering the back of the light
Once that is off you will see the prongs of the bulb.
The bulb is held in place by a wire clip, push it forwards and out to release ( same system on any bike/ car)
Remove bulb by bringing it out backwards.
Replacing with, new one the reverse.
DO NOT touch the new bulb with your fingers, as it will shorten the life. (the bulbs not yours)
:cool:
