turning your bobbin's
Started by tapps, July 27, 2021, 10:02:47 AM
what size bolt's do you use to rotate your BOBBIN'S  :tt2:
KENNETH0405
Hi I just use a 10mm Allen on a socket seems to do the trick  think it depends on how tight they are ..spray some brake cleaner first or wd40 lightly ensure to clean disc afterwards
Kenny
personally I wouldn't  put WD40 anywhere near a brake disc
Rynglieder
On the GSX1400 the usual method used by owners was a screw extractor inseted and turned by hand or a low speed battery drill.
TBH it is not something I have yet felt the need to do with the GTR.
I'd also be dubious about using lubricant around the brakes, but a bit of brake cleaner might not hurt to ease things up perhaps?
Tynesidebob
The best way to sort the seizing bobbins is to fit Brembo discs and forget about it.
