Different FI Error
Started by Tynesidebob, July 01, 2020, 07:34:08 PM
Tynesidebob
My 2011 bike starts straight away - no problem....when it's cold. But when it's hot (ride then tea break) it starts fine then after 30 seconds - red light, FI error and ktrak light. Ride for a couple of minutes then switch off and back on and everything is normal again with no stored codes. This happens almost every time it is started  when hot.
The engine runs perfect even with the warning lights on.
I just restart it whilst riding along now but it would be better if it didn't happen in the first place.
Anybody had this before?
I suspect it might be an air box sensor getting hot from the engine when stationary then air cooled when riding but I am just guessing and don't understand why there are no stored codes.
All suggestions gratefully received.
Freddy
You can access the fault codes only while they're active, so you need to do the button pressing thing then - not after the warning disappears.
Tynesidebob
All sorted now.
The problem disappeared when I got the ecu ref lashed by Michael Cox so everything is running great now.
