Rad re-jig info / help
Started by Stolichnaya, November 08, 2017, 10:18:48 PM
Stolichnaya
Looking for help on my Rad please.
The fins are fairly bent over and looking nasty. The rad is watertight and no loss of coolant on a June trip in Italy at a fast pace - 37 degrees outside temp and the bike was on 3 bars on the temp gauge all of it but it was HOT!!
Am I being unduly cautious? Are they all like it?
I've seen the fender extensions but as mine never had one and it's a 2010 bike it's a bit like polishing a turd to add one now?
Do I re-core it? Buy a foreign copy?  Anyone bought a copy and had good results?
Used genuine ones on eBay £250+ and look no better than mine
Stoli
ICAQ
AQIC
I82Q
B4IP
ChrisB
Take it to a radiator repair specialist who should be able to pressure test it and advise on condition of fins etc. He may be able to recore it if required.
Buy a black R&G radiator cover and forget about it :grin:
Paul B.
wildybeast
 :agree: If the cooling fan is cutting in and out then all is good.
Stolichnaya
Quote from: O.C. on November 09, 2017, 07:44:58 AM
I'm with the view that if its working then don't fix it ....Add a Radiator Guard
This might be of some use  :yes:
https://www.ebay.co.uk/i/371545963907?chn=ps&dispItem=1&adgroupid=51318944048&rlsatarget=pla-381868100861&abcId=1128956&adtype=pla&merchantid=101764276&poi=&googleloc=9045177&device=c&campaignid=857338527&crdt=0
STUNNED - i didn't even know these things existed!  top work thank you.
I'm going to buy one and spend many hours with tongue at side of mouth doing each fin.
I will also buy a guard - seen one for £25
thanks for the top-tip
Stoli
ICAQ
AQIC
I82Q
B4IP
You're very welcome...hope it works  :clap:
Stolichnaya
Quote from: O.C. on November 09, 2017, 12:06:15 PM
one bought and booked myself for garage time Sat and Sun.
as for ebay finds, ive just bought a set of these
https://www.ebay.co.uk/itm/Fold-Extend-Brake-Clutch-Levers-For-Kawasaki-ZX1400-ZZR1400-2006-2015-titanium/191892645040?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
ive had a set on my GSX14 and they've been fantastic - i know I'm now going to draw all sorts of "ooooh you don't wanna do that..."
BUT I DO AND I HAVE !!!  the GSX14 set have been fantastic - so there all you nae sayers
ICAQ
AQIC
I82Q
B4IP
Quote from: PaulB on November 08, 2017, 10:57:12 PM
Paul B.
+1
Quote from: Stolichnaya on November 09, 2017, 12:23:59 PM
Good for you John, do what you want it's your bike after all  :clap:
Robbieben
Radiator fins are quite easy to straighten up, just as they are easily distorted by water leaving your front tyre at high speed. I'd always suggest a radiator protector but before you fit one try to straighten the fins back into line, they won't go perfectly as they will have stretched slightly, just try to create a good open air path. I use a plastic knife which I trimmed down to it's more meaty handle, created a blunt chisel type tip first by sharpening up then heating it up and rounding it off. It now resembles some film style prison impliment to hurt someone....just blunt, certainly does the job though. :smiley:
Stolichnaya
Quote from: O.C. on November 09, 2017, 01:17:21 PM
100% on the nail OC.  its mine you hear...  ALL MINE !!
I'm also getting my good friend Maccie back in to do some more Pinstriping.  ive already had the fairing done (pikkie below) but now I'm adding the later GTR14 stripe that goes on the edge of the fairing...  in Old Gold of course
ICAQ
AQIC
I82Q
B4IP
Stolichnaya
Quote from: Robbieben on November 09, 2017, 01:49:39 PM
thanks for the tip - i couldn't ever have the patients to do one by one - id be there all year so bought one of those thingamyjigs above and plan to be in the garage Sat & Sun
ICAQ
AQIC
I82Q
B4IP
