Re-shimming the valve gear.
Started by doebag, November 03, 2017, 11:01:24 AM
#30
No, headlight and fairing remain in place.
The front mounting bolt is up above the mirror, to left of instrument cluster.
My version of your photograph......
badaboum
I will work on this monday morning
I hope i'll be able to do this
THis is pretty hectic!!
SIncerely
French 2008 GTR 1400
-> Motax back wheel cover
-> Phillips H4 Xenon light
-> 2 motorcycles speakers+amplifier+remote
-> Integrated Hugel GPS+MP3 player in the ''glove box''
-> Kawasaki Top Case
-> Cee Baleys Screen
-> Akrapovich Silencer
Quote from: badaboum on January 19, 2018, 10:15:20 AM
SIncerely
Keep reporting back. Getting access is a pain, once you are in there, the actual measuring and shim changing is not too bad.
Freddy
Quote from: doebag on January 19, 2018, 11:38:33 AM
I can't agree.  It's no job for a novice or even the semi-skilled.  It's a good thing to know one's limitation and stop there.
This is why I get mine done by my mechanic!
Quote from: Freddy on January 19, 2018, 11:07:59 PM
I agree too, 'a man's got to know his limitations' [Dirty Harry Callaghan, 1973]
But if you are competent, then once the cams are exposed, measuring clearances and changing shims in no more difficult than other bikes, in fact with the cam chain on the end of the crankshaft, there is no risk of losing the chain into the bottom of the engine, as on some older bikes.
Quote from: PRD on January 20, 2018, 08:33:07 AM
I don't know what Kawasaki charge for this job, but I guess a big part of the labour charge, is removing/refitting body work etc.
badaboum
#37
Guys
So far I didn't found it hard or needed to be a mecanics to arrive where I am. It's just a pain in the ass because the amount of parts to remove (and to reffit) is crazy
In france, the 42k service is between 800 to 900€
Freddy
#38
Quote from: doebag on January 20, 2018, 09:35:37 AM
But if you are competent, then once the cams are exposed, measuring clearances and changing shims in no more difficult than other bikes 'with shim-under-bucket-4x4-valve-head'  in fact with the cam chain on the end of the crankshaft, there is no risk of losing the chain into the bottom of the engine, as on some older bikes.
Agreed - competent, being the operative word but it's not simple or easy even when somewhat experienced.  It is more complex and difficult than most due to restricted access.  Let the novice and semi-skilled be warned, very warned.
Good luck with it badaboum.  You will no doubt find them all within spec, which will save you.
ChrisB
Quote from: Freddy on January 20, 2018, 10:03:32 AM
I also agree. Took my bike to Taylor Brothers last week, a small firm recommended by several people on this forum. I also know that he services the Staffordshire Blood Bikes so comes well recommended. Dropped the bike off Wednesday morning and picked it up on Friday lunchtime. very friendly and knowledgeable, did the job at the price he estimated and additional work at no extra charge. 26,000 mile service including tappet shim inspection £350 to £400 job done. I also got him to put on a rear PR4 GT, which he fitted for a very competitive price. Great people to deal with and I will certainly use them in future for all servicing etc. I live in Stockport which is a 125 mile round trip for me, but I consider it worthwhile.
https://taylorbrothersmotorcycles.co/
I've done the shims on a variety of bikes in the past.  ZRx1200, ZZR600, ZX6R and 9R and some Suzukis, but I've just had the shims on the GTR done by Bournemouth Kawasaki.  Rather too cramped for my big mits.
I did pull off all the panels and belly pan.  They also put in new plugs at the same time as it seemed silly not to do so when all the engine is exposed.  It needed all the exhaust valve reshimming and after a bit of juggling, just one new one on the inlet side.
It gave me a good opportunity to give all the ionnerds a good cleaning.
Taking off and refitting the panles myself saved about £200 in labour charges
badaboum
#41
Guys
I managed to remove the cylinder head cover and my plugs. They are all within range and looks very good
Now I need to work on my measurement of the clereance...
Any tips?
THanks
badaboum
And quick question about the manual
THe mean values are :
exhaust  0,125mm
Inlet      0,145mm
But the standard valves clearence given in the book is :
exhaust : 0,19 to 0,24mm
Inlet        0,12 to 0,17mm
The mean value at inlet is within the clearance range given. So that's ok
For the Exhaust, I don't understand why the mean value is outside the range. Any idea?
Quote from: badaboum on January 24, 2018, 10:34:17 AM
exhaust  0,125mm
Inlet      0,145mm
But the standard valves clearance given in the book is :
It's a misprint/transposition, the mean value of 0.19 to 0.24 is 0.215
badaboum
Did my measurement twice
All my exhaust value are off.
Removed the ACT, and ordering new shims
