Glovebox removal
Started by BruLan, May 25, 2017, 07:46:16 AM
BruLan
If this has been asked before then apologies in advance.
I have just bought an 08 Bike, and want to fit a Tank Bag.
Obviously the Glovebox in front of the Filler cap precludes that
My question therefore is, is it possible to simply (??) remove the Glovebox and fit the cover from the later model ?
Any help appreciated, Thanks in advance
wildybeast
yep. my mate has just done it for your reason.99.9% sure all you need is the cover/rubber trim and bolts.There is a removable bracket underneath which holds relays but ime sure the holes lined up.
BruLan
Quote from: wildybeast on May 25, 2017, 07:56:42 AM
yep. my mate has just done it for your reason.99.9% sure all you need is the cover and bolts.There is a removable bracket underneath which holds relays but ime sure the holes lined up.
I hope thats possible, Cradley Heath Kawasaki have the new cover but they are no 100% it will fit, so need some reassurance before buying at £65
wildybeast
Do a swap on here. or buy s/hand.Ime quite possitive it will fit.As i  said my mate has just done this  :punk:
wildybeast
Just to add his bike is a 2010 model with the 08 glove box so it deffo fit.
BruLan
Well I'm going to take a punt, I'm sure they will have it back if not
Thanks !
wildybeast
 :clap: It will fit. make sure it comes with the rubber seal which runs around the edge. :clap: :clap:
BruLan
Quote from: wildybeast on May 25, 2017, 08:30:54 AM
Here's hoping  :hammer:
ChrisB
I have a 2009 model with tank mounted glove box and have used a magnetic tank bag for 6 years without any problems.
#9
+1  10 years for mine.
BruLan
Quote from: BruLan on May 25, 2017, 08:39:49 AM
Hello Mate, dont know how your Mate did it but it dont fit, the back screw Holes are way out !
Sending Back for refund DOH !!
#11
That probably means the bracket holding the relays is different.
I have a spare bracket, let me dig it out and photograph it.
BruLan
Quote from: doebag on May 25, 2017, 02:41:07 PM
That would be excellent, I will hold off posting it back
Picture in my last post
BruLan
