Garmin Zumo 350lm BATTERY NEEDED
Started by KENNETH0405, April 03, 2017, 10:08:05 AM
KENNETH0405
I have a garmin zumo 560 lm battery seems dead HELP !!! Where do I source this???
mikeyw64
Might be worth contacting Garmin directly,
I need a battery cover for mine (long story short, stood on it when it was off & broke it)  , couldn't find one for sale anywhere.
Contacted Garmin , explained what I was after and they sent me one next day FOC :D
#3
Quote from: KENNETH0405 on April 03, 2017, 10:08:05 AM
They can be notoriously difficult to obtain through 'normal' sources....I agree ----- contact Garmin direct
#4
Just found this which may be of interest
There are  reports of low battery life on the garmin forum...you will have to register and sign in to use the search facility
Basically the suggestion is to make absolutely sure that the connections of your battery to your GPS unit are good, although this is mostly with 590 & 595 LM models ....may be worth a try all the same
Good luck  :smiley:
KENNETH0405
 Found this on eBay item no ..172597252674 a little dubious  as seller does not have a lot of feedback and it's from Hong Kong ....might be worth a punt though
Thanks to all forum members for help
Do you have a 350lm or a 560?  Are they the same?  Too many choices.  I'm confused as always.
