Mini airman pump
Started by Zebedee, July 09, 2014, 11:55:24 AM
Zebedee
After a conversation the other day as to wether the Auxiliary socket would be able to power one without blowing the 5A fuse or would an additional one be required,  thought I would clamp it and find out :) Results are my pump under load to 42psi draw was 6.3A Peak 7.8A at switch on. So the answer is you may get lucky and it will be ok but would not want to rely on this in an emergency so a connection to optimate lead will be sourced.
Just incase you wanted to know ;)
(Amended after Viper's comment below)
Zeb
Zebedee
Quote from: Zebedee on July 09, 2014, 11:55:24 AM
After a conversation the other day as to wether the Auxiliary socket would be able to power one without blowing the 5A fuse or would an additional one be required,  thought I would clamp it and find out :) Results are my pump under load to 42psi draw was 0.624A. So the answer was yes the OEM one is fine for my needs :)
Zeb
ive been using one in the socket for a while I bought it of amazon its digital and I set the pressures now problem blowing fuses its in the panniers all the time. :agree:
Ring Automotive RAC600 12V Digital Air Compressor Including Storage Bag now only £20
Zeb
0.62 amps is incredibly low , was your meter set right, should it read 6.2 amps as that still would not blow the fuse, my mini pump from wilcos , pulls 9 amps at start and settles to 7 amps
Zebedee
@ Viper, thought this was incorrect overnight so  have rechecked with another meter, blown the fuse 1st time and now have amended first post to reflect true findings.
Zeb
Zebedee
Quote from: Zebedee on July 10, 2014, 07:10:24 AM
Zeb
glad you got it sorted, the glass fuse will generally go 15% over their rating .
Zebedee
It's not the glass fuse I was concerned about its the 5A in the bike.
Zeb
Zebedee
Quote from: Zebedee on July 10, 2014, 05:46:58 PM
Zeb
I don't know why I said glass fuse, its a mini blade, Doh, senior moment
Zebedee
Cos there's one in the pump? ;) think that has you covered lol
Zeb
Zebedee
