Inspection Front brake caliper and brake control disk wear and tablets
Started by MGvalerio, June 03, 2013, 06:24:40 PM
I hope you cleaned the pistons and callipers before you put it all back together, I'm also surprised you didn't use a torque wrench on the pad pins and calliper bolts, gotta be careful with them.
MGvalerio
Quote from: Lonewolf on June 03, 2013, 11:33:45 PM
Il clima Italiano e una ispezione suntuaria programmata( 2 mesi) evita formazioni occumoli residuo parti attrito,32.000 miglia con un solo cambio di parti attrito( PASTICCHE FRENI)
Chiave dinamometrica  :rip:no grazie per queste ispezioni.
MG valerio. :chef:
Deon
Quote from: MGvalerio on June 04, 2013, 05:20:13 AM
MG valerio. :chef:
En ek weet nou presies wat jy gese het ! Hoekom praat jy nie Engels op n Engelse forum nie ???  :ohplease:
Deon
Et bien, il n'utilise pas l'Anglais car il ne veut pas.
Si quelqu'un veut savoir ce que il dit ils peuvent utiliser les traductions de Google (ou les autres).
Si non, ils peuvent l'ignorer.
Quote from: Boomer on June 04, 2013, 12:52:37 PM
:agree:  «ils ne peuvent ignorer" .... ce qui est précisément ce que beaucoup feront
Andiamo MG, i tuoi post sono spesso informativo e utile, fare un tentativo di condividere le tue idee con altre da loro traduzione    :ohplease:
MGvalerio
Quote from: olde coney on June 04, 2013, 01:12:52 PM
English
Spanish
Arabic
The climate and Italian plus a scheduled inspection every (2 months) prevents the formation of residual friction of the parts, I've done 32,000 miles with only one change of parts of friction (PADS BRAKES)
I do not use the torque wrench for these inspections.
MG valerio. :popcorn:
MG, If you post in Italian, many people will ignore the post.
Some, like me & OC will translate it with Google Translate and comment but many won't.
If you post in English, many more people will read it.
Also, when translating to English, be certain to use simple Italian or the translator will not work correctly.
MG, Se pubblichi in italiano, molte persone ignorerà il post.
Alcuni, come me & OC sarà tradurlo con Google e commento, ma molti non lo faranno.
Se pubblichi in inglese, molte più persone lo leggeranno.
Inoltre, quando si traduce in inglese, essere certi di utilizzare semplice italiana o il traduttore non funziona correttamente.
stoketim
Here for a good time, not along time
I always ignore what MG writes if its not in English... I could use google translate BUT this is a English forum so I wont...
English OR I will Ignore..  :popcorn:
Quote from: Debs on June 05, 2013, 02:00:47 PM
Ti vogliamo tutti bene Debs  :mfr_lol: :mfr_lol:
