Side light bulbs
Started by BigAlan, June 29, 2012, 08:01:04 PM
0 Members and 0 Guests are viewing this topic.
Those two under the headlight, what's the spec of them?
I need one, but will buy two.
Quote from: BigAlan on June 29, 2012, 08:01:04 PM
W5W 501 T10
its a very standard bulb , halfrauds ect
PIGINAWIG
Stupid question......
I need to change a sidelight bulb as well - dropped the little plastic bit out under the nose with the 4 x retining clips - can see the rear of the connectors - have pulled and twisted and they won't budge! Any ideas?!!
Black 2008 GTR with a good few gizmos.....
Quote from: PIGINAWIG on July 02, 2012, 01:15:50 PM
They twist and come out if I recall correctly. You certainly don't need much force
Mogster
Quote from: Kwikasfuki on July 02, 2012, 01:22:49 PM
Ahem!!!!...may I refer you to item 10 of the (Mogs) Haynes guide to motorcycle fiddling... http://www.gtr1400.co.uk/forums/index.php/topic,1130.msg12757.html#msg12757
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part and remaining glass shards.
Quote from: Mogster on July 02, 2012, 01:29:28 PM
:mfr_lol:
PIGINAWIG
Cheers - there's no easy way  - rubber housing needs a good yank and they're done.....all replaced with LED so jobs a good 'un.   :clap:
rubber housing? I can't recall rubber housing! We are talking about those LED bulbs at the front right?
PIGINAWIG
Yep - the little 5 watt ones - there are two very close together between the headlights!! The bulbs are held in place by a soft grey rubber housing - just pull em straight out, change the bulbs and push back in place!
