May 17, 2026, 10:37:34 PM
Some info required please..............
Started by Bluesman, November 04, 2025, 08:52:20 PM
Bluesman
November 04, 2025, 08:52:20 PM Last Edit: November 05, 2025, 02:17:32 PM by Bluesman
I'm about to start the valve clearance job on my GTR, what are the parts I definitely need to order? I'll change the spark plugs as well. The bike is an 07 and has done 25,556 miles. I believe the check should be carried out at 26000mls.
Cheers guys
2007 Kawasaki GTR 1400 ABS, 2000 Suzuki TL1000R ,1983 1100 Suzuki Katana
You'll definetly want to replace the valce cover gasket and the spark plug tunnel gaskets.  I'd also think about servicing the fuel pump in the tank while its off
I think it's the tools you'll need. From memory it's very very tight working in there
Bluesman
Quote from: Bluesman on November 08, 2025, 11:57:55 AMThanks guys, appreciate it.
There's a video done by a member of one of  the American forums that I followed. Even then it was a pain with all the bits that you have to take off.
The space to work in there is very tight
When my GTR was due the valve service , my dealer quoted about £1000 .  I waited until a quiet time of the year for them, took off all the panels I could, supplied my own shims and they did it for about £500 in the end.
Replacing the spark plugs is a no-brainer when youve got that far into the engine
Freddy
It ain't no job for a novice - especially if they need adjusting.  Precise measurements are critical - to state the obvious.  More than one owner has been sorry to have gone into it.
Bluesman
Job completed!!
All 16 valves were on the tight side, just below bottom limit, to be expected on its first check.  She fired up with no problems. Valves sorted, new air filter, spark plugs. Just brake / clutch fluid and coolant change to go. Thanks for the help and advice.
Well done.  That's a big achievement 👏👏
Bluesman
Bluesman
December 29, 2025, 04:24:03 PM #10 Last Edit: December 29, 2025, 07:25:30 PM by Bluesman
Major service finished all ready for 2026 .......... :clap:
Valve clearances checked and all adjusted
New air filter
New spark plugs
Rear drive oil change
Engine oil & filter change
Brake fluid changed front & rear
Coolant changed
Clutch fluid changed
Fork oil changed
and 2 new tyres ( Metzler Roadtec 01)
How did you find doing the valve service? How many were out of spec?
Looks like a comprehensive service
Did you clean/replace the fuel pump filter?
