Camshaft timing marks off?
Started by crisp, April 18, 2022, 07:06:45 AM
crisp
Hi guys, hope I've posted this in the correct section if not can admin move please? I have replaced valves & timing chain on my 2017 (long story) but for some reason when the crank is set at TDC the intake & exhaust cam timing marks are off by about 1mm, intake mark being high & exhaust being low?  Would anyone know if this is acceptable or not? Tried to send pic's but do not have correct format. Thanks
Do you have the VVT set to minimum advance?
According to the manual they should be parallel to the head and each other.
The VVT only moves the intake cam so could be the cause.
crisp
Hi Boomer, thanks for replying. The VVT is fixed to the intake cam so I'm not sure what your trying to tell me? Are you saying the VVT moves? Ride safe
jonathan
Yes, the drive gear will move in relation to the cam to adjust the valve timing. That is how the Variable Valve Timing works.
crisp
What I dont understand is why the intake timing mark is 1mm high? The VVT must be in neutral initially?
