Bluetooth helmet kit wanted
Started by big mike, June 16, 2018, 12:09:26 PM
big mike
Anyone got a rider- pillion Bluetooth set up for sale
Tay
I don't have one for sale, but I had quite a bit of 'fun' with helmet audio with various headsets.
Headsets are not all create equal, it could just be bluetooth compatibility or just compatibility in general :)
I've used the older Scala ones and they were a bit hit and miss with the gear I have, sometimes it wouldnt pair with my kit,  I then tried the vertix ones,  I have an iPhone 7+ and a Garmin 590LM
I currently use the Interphone F3MC (There are newer models with loads of additional features, but perhaps less compatible with your gear)  mine works for audio directions and alerts from the Sat Nav, it can play Music too, it can take and make calls on the iPhone 7+, the Sat Nav can also pull traffic and weather down too.
However, I only use it for audio directions and warnings from the Sat nav.
Make sure you check the compatibility, I found a hidden away FAQ on the Garmin site with supported models and features and was surprised that some things work but with limited capabilities.
If you have the option to test first then great or get a shops recommendation so you can take it back if it doesnt all work.
Just a heads up :)
