Screen Relay
Started by rodneyjd6, February 26, 2017, 04:44:54 AM
rodneyjd6
Hi the screen on my 2008 gtr 1400 has blown 2 relays now  the up relay keeps blowing and ideas on what would be causing this?
wildybeast
Do you have the correct size fuse fitted.i would check all earth connections to. Also the mechanism and or the motor maybe seizing up . If you remove the screen and black plastic pannel on the nose cone you can see all of the workings.Give them some lube and the motor to if you can. Good luck also have read of this thread http://forum.cog-online.org/concours-14-zg1400-general-chat-and-tech/windscreen-won't-adjust/msg484589/#msg484589
