F1 warning now bikes dead !! NOW WORKS !!!!
Started by Stolichnaya, July 31, 2016, 12:13:02 PM
KIPASS ECU Communication Error (Service Code 39)
KIPASS ECU Communication Line Inspection
○When the data is not sent from the KIPASS ECU to the
meter unit, the service code 39 is displayed.
○The data is sent through the CAN communication line.
○The service code 39 is detected with the meter unit. •Inspect the CAN communication line (see CAN Communication
Line Resistance Inspection in the Fuel System
(DFI) chapter).
If the CAN communication line is normal, check the
KIPASS ECU (see KIPASS ECU Power Supply Inspection
in the Electrical System chapter).
If the KIPASS ECU is normal, check the meter unit (see
Meter Unit Inspection in the Electrical System chapter).
If the meter unit is normal, but the problem still exists, replace
the meter unit (see Meter Unit Removal/Installation
Stolichnaya
Thank you. It's now on optimate and I changed fob one last month.
ICAQ
AQIC
I82Q
B4IP
