Battery tender
Started by Charlie farley, March 17, 2016, 08:39:06 PM
Charlie farley
Good grief not him again !!
Can I use the power socket on th dash to conect a battery tender ?
Charlie
snowy
Not sure how it's wired up, but if it's live with ignition off, i.e. always on direct to battery, yep, plug away! :yes:
If its just on with ignition, connected to auxiliary circuit, no connection to battery so nada! :no:
Dick Snow.
Charlie farley
I suspect its with ignition so a hard wire straight to the battery is no problem .
Thanks charlie
battery tender through power socket does not work
I fitted an extra power socket where the blank is on the left hand side of the instrument cluster, wired directly to the battery through a fuse. Always handy having more power sockets when touring, and easy to connect a battery charger up to the bike this way if needed.
Standard dashboard socket is a switched supply...so no,  :smiley:
