What Batteries are needed for the Transponder Keyfob ?
Started by PCPeteUK, September 23, 2015, 11:11:10 AM
PCPeteUK
Hi All,
I have the dashboard flashing that the transponder key fob battery is low - What Batteries are needed for the Transponder Key fob and is it an easy swap ?
Do I need to re synch the transponder to the bike afterwards?
If so how please?
Many thanks in advance for your pearls of wisdom :)
Rgds...Pete
In the US we use CR2025.  It's an easy swap.  You just have to pry open the key fob.  There is no syncing required.  Drinking yes, syncing no.
Gonome
Hi Pete,
I use Duracell CR2032. Readily available from the likes of Sainsburys.
Regards,
Better to be old and grey than the alternative!
2032 is what is specified for the TP sensor.  If you add an L to that battery you get pre-attached leads.  Does your manual specify the 2032 for the key fob?
PCPeteUK
Thanks all - I used the CR2025 and worked perfectly - thanks, no more error issue...
Rgds...Pete
I've got a chain and a clip on mine.  Hook it to the belt buckle and put it in my pocket.
Quote from: O.C. on September 24, 2015, 09:06:23 AM
    :clap:   A picture is worth a thousand words
BTW is the fob/lanyard string a genuine Kawasaki accessory  :mfr_lol:
Its the lanyard from a F1  pit lane pass,   Abudabi
I wear it around the neck on the lanyard cannot forget or lose it.
