code 23
Started by trousersnake01, June 22, 2013, 02:56:06 PM
Chaps.  I had a non start today and For warning came on with code 23 showing. Has anyone got knowledge of this please.  This happened the other day and I eventually got it started but today it wasn't having any of it.  I just know its going to cost me money.
Nicked from the Concours Owners Group Forum..  :popcorn:
Service Code Table
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor (EX) malfunction, wiring open or short
24 Speed sensor malfunction
25 Gear position switch malfunction, wiring open or short
26 Camshaft position sensor (IN) malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
37 Steering lock unit communication error
38 FI ECU communication error
46 Fuel pump relay malfunction, relay is stuck
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
59 Valve timing abnormal
62 Subthrottle valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
65 Oil control valve solenoid malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
68 Steering lock unit malfunction, wiring open
83 Oxygen sensor #2 inactivation, wiring open or short (Equipped Models)
87 Steering lock unit identify authentication Error
88 FI ECU identify authentication Error
Richard
Handy list
Looks a good place to start, the manual has the removal / testing info in it
http://www.gtr1400.co.uk/forums/index.php/topic,297.msg24356.html#msg24356
Has anyone got a picture or diagram of where this component is please
Richard
Quote from: trousersnake01 on June 22, 2013, 10:46:35 PM
Pictures, diagrams, removal / testing info all in the workshop manual in the link above.
Thanks everyone,
Richard, do you know what it is listed under as I have flicked through all 800 pages and I have obviously missed it.
Richard
Quote from: trousersnake01 on June 24, 2013, 11:23:27 PM
In the PDF document
Page 177
Page 660 >
Richard
Thanks guys, its been picked up today whilst Im away for a weeks leave. So no doubt Im going to have a massive bill when I get back. The mechanic said if one has gone it may be worth replacing both as the other may go soon and it will cost for the double stripping down.
But we will wait and see
lets hope it isn't too expensive to repair......good luck and let us know how you get on   :smiley:
