What's Causing This?
Started by Sharpy, October 07, 2012, 07:03:41 PM
Quote from: Deon on October 10, 2012, 05:47:27 AM
Fully agree !!!   :yes:   Not fit for purpose.
Deon
:agree:  good idea
kfshman
I know a person who had similar problem it took the dealer a long time to discover the problem and at the end it was the throttle position sensor. the code is no. 11, have them check it
Quote from: kfshman on October 10, 2012, 07:03:02 AM
now there's an idea and deffo worth a try, nice one kfshman  :clap:
These are the Self-Diagnosis Service Code Reading codes for the 08-09 Concours 14:
11 -  Main throttle sensor malfunction, wiring open or short
12 -  Inlet air pressure sensor malfunction, wiring open or short
13 -  Inlet air temperature sensor malfunction, wiring open or short
14 -  Water temperature sensor malfunction, wiring open or short
15 -  Atmospheric pressure sensor malfunction, wiring open or short
21 -  Crankshaft sensor malfunction, wiring open or short
23 -  Camshaft position sensor (EX) malfunction, wiring open or short
24 -  Speed sensor malfunction
25 -  Gear position switch malfunction, wiring open or short
26 -  Camshaft position sensor (IN) malfunction, wiring open or short
31 -  Vehicle-down sensor malfunction, wiring open or short
32 -  Subthrottle sensor malfunction, wiring open or short
33 -  Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
37 -  Steering lock unit communication error
38 -  FI ECU communication error
39 -  The 2010 manual lists error code 39 -  as a KIPASS ECU communication error.
46 -  Fuel pump relay malfunction, relay is stuck
51 -  Stick coil #1 malfunction, wiring open or short
52 -  Stick coil #2 malfunction, wiring open or short
53 -  Stick coil #3 malfunction, wiring open or short
54 -  Stick coil #4 malfunction, wiring open or short
56 -  Radiator fan relay malfunction, wiring open or short
59 -  Valve timing abnormal
62 -  Subthrottle valve actuator malfunction, wiring open or short
64 -  Air switching valve malfunction, wiring open or short
65 -  Oil control valve solenoid malfunction, wiring open or short
67 -  Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
68 -  Steering lock unit malfunction, wiring open
83 -  Oxygen sensor #2 inactivation, wiring open or short (Equipped Models)
87 -  Steering lock unit identify authentication Error
88 -  FI ECU identify authentication Error
How to access codes
-First have the key off.
-Push and turn the key knob (stove knob key) to on.
-Push the upper and lower buttons for more than two seconds. Self diagnostic mode starts.
-The service code(s) are displayed on the dash (LCD).
-Turn the stove knob key off.
This place is a mine of information :laugh: :laugh:
Barry7
Wow!  Thanks Pistole that is fantastic info, I will be printing this off and keeping nice and safe for future info.
Any more gems like this, more than welcome.........
Never eat Yellow Snow!
Deon
good advice, tell them to collect the bike , repair and deliver back to you in 5 days or give you a refund
Sharpy
Crumbs!
Haven't been on the forum for a few days and looks like members are as riled as I am by this.
Haven't heard anything from the dealer yet and will have to phone for an update in a bit.
Must say that I'm not too impressed so far.
When I took the bike back the owner/manager who did the deal didn't even acknowledge me when he walked past me in the shop a number of times. He knew the problem I'd had and that I'd had to take time off work etc to get the bike back.
I had to bite my tongue as I just wanted them to get on and fix it with no side issues to cloud the matter.
Believe me I'm not used to biting my tongue and I would have rather liked to have a very frank discussion.
Will update when I know more.
Thanks for all your interest and advice!
Sharpy
Just made a quick call to the dealers who were, spookily enough, just about to call me.
The update is that there is no update. The problem is still there and they have tried swopping parts out from another GTR to see if that solves the problem with no joy.
Not getting a good feeling about this as the guy said once they found the problem they would contact Kawasaki to see what they could do to help. The bike is out of warranty by the manufacturer but is covered by a 3 month dealership warranty.
probably why such a low milage bike was traded in, id encourage the dealer to update you via email , just so you have proof if anything goes pear shaped. as i said before , give them a time limit before you get a refund
Reject it now, don't be disheartened by this experience, you have just been VERY unfortunate. Bin it and get another from elsewhere.
- since they're at the "swapping to see" state , what they might want to try is to swap out the entire throttle body with their other gtr (alot of work , this).
- on the gtr , there are the primary throttle plates operated by cable from the grip , and also a duplicate set of secondary throttle plates operated by servo by the bike's ecu.
- any failure of these parts may cause the lurching at small throttle openings.
- if its an injector fault or a fault with the TPS , the swapping of the TB will also show it up.
- good luck.
Deon
Quote from: Lonewolf on October 12, 2012, 01:02:47 AM
:agree: Do it now !!!!!!
Deon
Quote from: Deon on October 12, 2012, 05:48:14 AM
Deon
That would be my advice also....don't throw 'good money after bad' as they say
Sharpy
Got a phone call yesterday to say that the bike is fixed  :clap:
Turned out to be the throttle sensor. I'll get a full update when I pick it up this morning.
Mechanic has taken it out a few times since identifying the problem and it has not happened since.
Just hope the weather holds as I plan to take the long route home.
Was starting to think about asking for my money back but if the problem is solved I'm more than happy to keep the bike and get on with putting some miles on it!
Thanks for all your interest and advice: very much appreciated.
I wonder if the owner/manager will acknowledged / speak today...... I suspect his customer service skills will continue to be  :shit:
I guess I just have to accept that I was so lucky that he let me buy the bike from him. :nono:
The guys in the shop have turned out to be great with an interest to resolve  the problem.
I'll post later with an update on how the bike went on the way home.
