Front Wheel Chock
Started by Debs, September 10, 2012, 01:16:47 AM
#45
fairy muff.. Mr olde coney :smiley: but I don't have a ramp. I only want to raise the front wheel of the ground, so I could clean the front wheel,checked the head and wheel bearings, and store the bike over winter lifted clear of the ground taking the bikes weight off the rear shock and front suspension. also thought this may be a easy solution to deb's storing problem by making the bike more secure and the ease of checking both front and rear brakes are running free through out the storage time. also the "make shift jacking block" makes cleaning the front wheel and maintenance checks alot easier :yes: the block of wood took me just 15 minutes to knock together. sometimes the simplest solution is the easiest solution :smiley:
Yep, its a good idea Dave, and saves the cost of a lift too   :wink:
Quote from: olde coney on September 16, 2012, 02:22:39 PM
If I need to get the old girl right off the deck I generally shove her onto the Lift
There you go with the innuendo again  :sweatdrop:
