What plug is this ?
Started by trousersnake01, July 10, 2012, 09:29:01 PM
Chaps, do you recognise what make this plug is please as I want to order the other side of it, I gather its for an optimiser type thing but I don't know which one and if I need the male or the female ?
Ta very much.
Hans
Yep! Wirred to your battery - for battery optimizer....  :-)
Cheers,
Hans
<DK-Odense>
When I pulled the rubber cover off to look, it was full of water, not very good.
Hans
Let it dry out... contact spray... then silicone spray... then you're good to go!
Cheers,
Hans
<DK-Odense>
100milesaway
Optimate 111  At the other end of that are the metal eyelets that connect to the battery. :yes:
What for?  The lead you have has the connector to attach to the charger.  The charger has it's opposite connector to mate with the one attached.  The one you have has it's waterproof cover which has probably not been fastened properly or closed after getting wet. Mine has never had water ingress
Winston, the lead is attached to the bike when I bought it. My charger is a different make so plug is not the same. So I need to change plug on charger, a lot cheaper then replacing a charger. My old lead has corrosion on it so not going to re use it so going to replace the charger plug and leave the optimate one on.
