2012 Front Disc Pads
Started by vfrtom, May 26, 2012, 12:00:53 PM
vfrtom
Can anyone supply the Kawa Part no for the 2012 front pads. Are they the same as previous models
Thanks
Tom
Mogster
i think that they are different as when i had mine done under warrenty they made a point of saying that Kwakaski had sent 2012 discs and pads.... are you changing yours for some reason?? wouldn't EBC ones be a better bet.
You are looking for ...FA417/4HH ... :smiley:
vfrtom
Thanks guys
This looks like the EBC part no.
This is all part of my battle over the discs worn out at 20k miles. I know the padds were changed in 2010, but I have heard they were changed in 2012. If this is so, it indicates a problem with the 2010 set up which is the base of my argument. If I can establish a 2012 change, I will go to small claims over this.
Tom
It may well be that Kawasaki don't deem the change between 2010 & 2012 to be down to a problem, they could simply present a case that the change represented a design improvement. That still wouldn't necessarily indicate that there was a fault with the 2010 discs.
Don't get me wrong I'm behind you 100% on this but I'm just thinking out loud as to how Kawasaki will potentially put the onus on you to prove what you are suggesting. Where are your facts, what evidence can you show the Courts?
Quote from: vfrtom on May 26, 2012, 12:00:53 PM
Thanks
Tom
2012
Disc:        41080-0570-5C
Pads:        43082-0122
2011
Disc:        41080-0564-11I
Pad:        43082-0112
2010
Disc:        41080-0102-5C
Pad:        43082-0112
2009
Disc:        41080-0102-5C
Pad:        43082-0071
2008
Disc:        41080-0102-5C
Pad:        43082-0071
vfrtom
Thanks guys.
My argument will be that there was obviusly a problem, as manufacturers do not change parts unless there is a reason. Clearly after two years, they had identified a problem
Suppose next question is will 2012 pads fit a 2010 model
Tom
