Seat Problems?
Started by cpettifer, November 22, 2011, 10:33:33 AM
cpettifer
Does anyone else have a problem with their seat not staying locked down? I struggle to get mine shut without it popping up again and then, sometimes when I get to work, or home, I find it's popped up while I've been riding. I've also discovered I can sometimes wiggle it open without using the key to open it.
Common problem?
I'm guessing it's something I need to get my dealer to sort out under warrantee...
Current - Kawasaki 1400 GTR
Previously - Kawasaki Versys, Honda 650 Deauville, Honda 125 Varadero
Is it popping up at the front or rear?
cpettifer
Popping up at the rear - where the locking mechanism is.
Take it back to dealer. Shouldn't pop out.
mecki
I had that once, but it seems to stay in place now.
fred24
I had the same problem - was caused by the metal tab on the rear of the seat that locates in the locking mechanism not being perfectly straight/vertical.
Bent it straight with a pair of pliers and its been fine since. It was only very slightly out so the position is very critical.
cpettifer
The metal tab on mine is bent. Presume this is the problem then. I'll contact my dealer - but probably live with it until 4k service.
It probably only needs a tweak of a mm or so one way or another. Get some pliers on it or give it a gentle tap with a big hammer.
100milesaway
Quote from: cpettifer on November 22, 2011, 03:18:50 PM
Mine was the same from new !!!! just get some pliers on the tab and bend it straight. Easy peesy. ;)
ChrisB
Could the cause be the wieght of the pillion? ;D
cpettifer
Quote from: ChrisB on November 23, 2011, 09:46:48 PM
I'll tell SWMBO where you like...
